Sado Rabaudi
The Vive Focus 3, Vive’s latest all-in-one VR headset with 5K resolution, 120 degree field of view and 90 hz refresh rate can now be connected to Vizard and SightLab either using a cable (such as the Vive streaming cable) or wirelessly using the “Vive Business Streaming” application. Here are the steps to get this going.
1. Make sure both the headset and controllers are charged
2. Turn on the headset by holding down the power button for 3 seconds (located on the back of the headset) and holding down the power button on the controllers for 1 second.
3. If the headset is not set up yet, you can set it up either through the Vive Manager Android or Iphone app, or within the headset itself (using the headset button).
4. Pair the controllers: The right controller is linked by pressing the Vive button and the B button at the same time. The left controller is linked by pressing the Menu button and the Y button at the same time.
Connect the Vive Focus to a wireless network (use the same one your desktop running Vizard is on if you want to connect to Vizard wirelessly).
5. Connect the Vive Focus to a wireless network (use the same one your desktop running Vizard is on if you want to connect to Vizard wirelessly).
6. Connect to your PC
7. You can also adjust things like the bitrate and sharpening of the image in the settings. It may be necessary to run at a lower bitrate when running wirelessly and not on a fast connection.
8. To run in Vizard, connect as a “SteamVR” headset (either with vizconnect or direct). For more information see this article or this page in the Vizard documentation. For vizconnect, go to Tools- Vizconnect and choose the “HTC/Steam VR” preset.
9. To run in SightLab choose the “SteamVR” option from the dropdown
For more information on connecting various hardware or VR solutions contact sales@worldviz.com
