Sado Rabaudi
The Manus VR Prime II Data Gloves combined with Vizard allows users to experience full hand tracking in VR. Interact and grab objects including the use of physics based interactions and gesture inputs. Easily add to any scene with Vizard’s vizconnect Manus VR integration. Click here to see a video of the Manus VR gloves being used in Vizard.
https://www.youtube.com/watch?v=mvipUNHwj5c&t=1s
For more information on using the Manus VR Gloves with Vizard, see the following Vizard documentation page
For more information on the Manus VR data gloves visit their website at https://www.manus-vr.com/
To access the latest version of Manus Core (the software needed for running the Manus gloves) sign up and login to the Manus resource center here.
Manus gloves with Vivetrackers and articulated glove models
(this is a default setup that is most commonly used)
Note that at times the offset may need to be changed for the hand. This is usually the “pre-pitch” and might need to be set to “90” or “0”. This can be accessed by opening the vizconnect file, clicking on “go directly to advanced options”, then on the “trackers” tab clicking on the “offsets” button.
To use the Manus gloves with a Vive tracker (most common method), select the “HTC Vive” preset in vizconnect, and then swap out the two hand controllers with Vivetrackers. Next, add “Manus VR'' as an input. Lastly, you can map gestures in the avatar tab to the Manus glove and then, under the tools tab, map the Manus gestures to initiate tool actions (such as a grab). Or use the sample vizconnect file provided. For information on Manus VR's updated SteamVR trackers see this page.
To use the Manus gloves with a glove model with articulated fingers this code is added to the postinit section of your vizconnect file:
If you want to track the fingers from one of the avatars included with Vizard, you can use this code:
Physics Based Interactions (Note: this is largely untested and may have some issues)
For physics based interactions, you can use this vizconnect file that has collide boxes attached to each hand bone. Feel free to make your own vizconnect file if you wish to use another hand model by using the following code for each bone you want to add a collision box to:
